ok guys, i got an issue but i hope will be an easy to troubleshoot fix. When its semi warm out say about 45 degree's or higher over night, no problems starting without plugging in. below that i have to plug in or will not start without several tries. Just had injectors replaced and full tests done about two months ago and FICM passed (so they said). Deal here is, what is a good way to test Glow plugs?
Bit of info is when i let the truck sit just while at work and go out for lunch, cranks fine when its upper 30's to low 40's. Leave that bad boy over night, AH NO. I will be testing the FICM later tonight again and will let you know.
HELP please!!!
HELP please!!!
