1991 F250 7.3 idi 4x4 Just did clutch and slave. started ran a minute....seemed to run out of fuel but has not. Lost the clutch safety switch at the same time. Is there a connection between the safety switch and the high pressure fuel pump. I turn the key on and attempt to start it at the solenoid. turns over does not fire. cracked open the fuel line just before the water filter......fuel trickles out, no real pressure. broke open return line, fuel trickles out . Where is the fuel pump relay. There is no power feeding the clutch safety switch. Can you help?
