Just finished replacing all 24 Lash Adjusters and Rocker Arms on my 2008 5.4l 3 valve F-250. I decided to do this due to “lifter” noise. As I had mentioned before, truck has always run great.
Well we finished up (certified mechanic did it for me) and it is still making the same lifter noise. Cam Phazer are okay and do not make noise. Lifter noise is appearant at all RPM’s. Truck runs great, idles great, etc.
All Lash Adjusters we removed were seized up, none of them allow for me to push the spring loaded pin down. We were certain this would fix it. Being that they were seized up, what does that do to the operation of the system? Now they are now, spring loaded, what changes in the system. Why is it still making the noise? Is it possible these new ones need breaking in? Being that it had been making the noise for quite some time, is there carbon or something that needs to be worked off, and these new ones will do that with time. Any and all advise, wisdom, thoughts, etc.
