I just finish putting in the remaned motor ,it started right up after filling the fuel filter . Runs for about one min really good then dies Then it starts back up after cranking it over a bit , step on the go pedal and it revs right up then runs for a while and dies. This is the first 7.3 i have ever installed and have checked everything i can think of. When it dies it sounds as if it is not getting fuel ! But the injector pump is full . Are there any pre start up rules im not following ? do you have to bleed anything ? I have a running truck with a 7.3 in it i can take parts off to try . any help would be grate thanks
