No Start...Help
I am new to the diesels, been rebuilding and fixing gas burners for years, so I took on my first diesel build, she's all back together, no start. the truck is a 96 f350 7.3 turbo, had no fuel to the fuel bowl, so i pressurized the tank, removed the schrader valve and finally got fuel there. Opened up the hpop rails on the heads, got oil coming out there. Cracked open the banjo bolts on the back of the heads, fuel running out there. Filled the fuel filter housing with diesel as well. Is this common, are these engines hard to start prime up, or start after a build. Any information would be helpful. Am I missing something here. BTW, reason for the rebuild, compressions all over the place, excessive ring blow-by, leaking timing and oil pan covers. As said, any tips tricks, or prayers would be wonderful
Thanks Jay
Thanks Jay
