I just changed my hpop and the reservoir is full but not showing any rpms
'02 7.3L Excursion 3.73 Warn Hubs AutoTranny
did you fill the HPOP reservoir before you tried to start the engine?
I figured out the issue was not building oil pressure. The gear was a little cocked the bolt was tight. I loosened the bolt checked gear and tightened it up and fitted right up. Now time to put the melling high flow Lpop on.
Reactions: John in OkieLand
I did I have changed five this year in different trucks. Just the first time I ever had this issue
