I just got done shimming my FPR, I used the kit from Diesel Innovations. I started with there .065" shim and got a reading of 60 psi (my stock pressure reading was 55psi), so I then put in the .075" shim (the largest in the pack) and still get a max reading of 60 psi. According to DI's instructions, the largest shim should put me at 70 psi or higher...what could be causing my low fuel pressure? I am taking my fuel pressure reading from the test port on the back of the fuel filter bowl. These are also idle pressure's, I don't have an in-cab gauge to see what happens under load. Could my fuel pump be weak? Could the pick-up screen in the tank be partially plugged? In the warmer months I do run B20 biodiesel, so that may have loosened/cleaned some junk from inside my tank and could be causing some plugging issues with the pick-up. Or could something else be restricting flow? My fuel filter was replaced only about 1,000 miles ago.
Oh yeah, lately the truck has been lacking in top end power when in the higher rpms's...lack of fuel supply? I've owned this truck for a year now and I know it had "umph" on top end when I first bought it.
Any ideas guys? /ubbthreads/images/graemlins/confused.gif
