1 - 18 of 18 Posts
Is john woods still building transmissions? I know you get what you pay for, any other options in same caliber? Dont have much confidence in rebuilt ford HD
He should be.
DieselSite is also selling a very good transmission according to reviews
The guys at precision transmission in texas seem to know what they are doing.
(No personal experience, but the dudes seem very knowledgeable)
Sent from my SM-N960U using Tapatalk
Which precision? Ft Worth or Amarillo?
Good point. Amarillo.
They have a YouTube channel.
Discussion Starter #6
What is the week link in stock 4r100? Is this addressesin hd4r100, assuming JW does
A lot of the components in the pre 02 models were aluminum. Later was steel. All of that is addressed in theHD model.
BTS
Sam Wyse
A1 of Georgia (Chris Garrett)
John Woods
Dieselsite (seems good, but hasn't quite earned the stripes like the other 4)
Discussion Starter #9
Last quote was $7200 for jw trans, ford hd looking better and better
Discussion Starter #10
Also JW is only a 2 yr warranty
Something isn't right there. For that much money, it is probably a full race trans or mostly. Even getting just a "stage 1" from any of the 4 guys I listed will be much stouter than just a Ford HD replacement.
Discussion Starter #12
Wish, just towmaster($6k plus instal....) local shop wanted $8500 with flex plate
BTS: full build is $5000; they have been considered one of, if not the best for a long long time
A1: stage 1 is $5000; holds 600 hp; Chris Garrett is a 4r100 specialist; he builds them for 7.3s and for the big power Lightning guys
Sam Wyse: stage 1 is $3400; holds 450 hp; stage 2 is $4400; holds 600 hp; he is at the top of the game as well
Discussion Starter #14
I think sam stage too would be my choice, just for components but a few people think the stage 1 is good enough. This is my first trans choice so i have no clue, out of ignorance i upgrade. Not sure id upgraded components like triple disk tc makes it lock up where i will spill my libation
I just installed a Sam Wyse stage 1 into my truck. I have 180/30 Full Force injectors, KC 300 sxe 63/73 turbo, bunch of other stuff to make it pretty much a complete Stage 1-1.5 build. I'm really happy with it, but I'd get on the list sooner rather than later if you want one. I ordered mine on May 28th and it took 6 weeks to get the transmission delivered. I also replaced the cooler with Mishimoto at the same time. I talked to Sam and Corey (CNCFab) and everyone agreed for the 400ish HP my PMR rods could take there was no point in paying extra for the stage 2 transmission.
Discussion Starter #16
Thanks for info, i think stage 1 would work just thought the better components of a stage 2 would be worth the upgrade but since i am new to what is needed to handle another 200k. Not sure if there are any negatives to the upgrade other than $900.
Discussion Starter #17
Do you have a tuner? Wondering how stock pcm program handles new torque converter and valve body. I think there was some reference on diff tunes or tunes maybe need to adjust
With the hyrda, all the tunes have a "modified valve body" version that adjusts for upgraded transmissions. This will be signified by a "MVB" at the end of the tune name in the software.
1 - 18 of 18 Posts
