I need your guys opinions here.
Heres the deal. Ive got a 2004 F250 Superduty with the infamous 6.0. As you might expect, its been pretty maintenance heavy. This first issue was a couple of years after buying it in 08 with the EGR Cooler and so forth. Dealer fixed it under warranty. They also replaced the turbo. Would have been over 3k to fix. The next issue was a year or 2 later about 1900.00 worth of front issues. Ball joints and so forth. Another year or 2 later and the EGR cooler systems goes again. Took it to the dealer and they said 3k to repair. I said no thanks and took it to Beans Diesel Performance in Mufreesboro TN to perform the EGR delete. 800 bucks plus another 1200 in other suggested redos or repairs. Engines been solid since. About 3 1/2 years or so with no issues. Last year, back in the shop for routine front end alignment only to find it needs another 1500.00 worth of front end work. Less than a year ago, another 1500 for more front end work. Then just last month, 3185.00 for 4 new injectors on the left side. This time they put in a fuel pressure regulator. Supposed to protect the injectors from going bad. At this point im about 12k in repairs. And thats not even including routine maintenance which isnt exactly cheap. Whats the verdict. Keep it and hope that all that has gone wrong is over with? Or sell it.
Thanks :|
Thanks :|
