I am trying to wire up a power wire for the H&S mini Maxx tuner. According to the directions and some forum threads, I should be able to tap into the white wire with blue stripe that is under the dash. It’s a blunt cut wire. I found it no problem.
My problem is there is no power to this wire when the key is on. I’ve tried with while in the accessory position, run with engine off and running. It’s dead. I checked the 10a fuse and it’s good. I even replaced with another just to be sure.
Has anyone else run into this problem? Any assistance on how to get power to this access wire would be greatly appreciated.
Pic below. My truck is a 2012 F350 in signature.
159588
What fuse did you check? The wiring diagram shows it's fuse #10 in the body control module - right side kick panel.
