99 f350 7.3 automatic. Can turn over the starter by connecting the studs on the cylinoid. Key on the "on" position bring wait to start, which functions normal but wont engage the starter. Wire harness has no smashes or obvious shorts.
Also the injectors seem to not be functioning either as it doesnt want to run off ether. Fuel is up to the filter and oil Resevoir is has its oils on cranking via the cylinoid studs.
Any thoughts would be appreciated. Thank u and thank u for this forum.
Trev
Trev
