Well, tell me what you think. I was towing about 8,000lbs this weekend. I would not make any boost til over 1200deg and 2500rpm and then it would only be around 10lbs. Seems very low to me. If I lost all boost going up a hill I was done, had to go about 45mph and 1300 degs, droping into 2nd a few times to get the egts down because they were really hard to keep at 1300, with no boost. It would get maybe 5lbs in 2nd @ 3300 rpms. I made a max of 22lbs boost with the chip turned up to 140. and egts would hit 1400 real quick. I was just seeing if I could get the boost #s up still, and was almost home going thru town on flat ground.
I use to get a loud squeel sometimes from the turbo when the boost is going up. And I noticed when i had 10lbs and it was droping There was almost a metal to metal grinding sound tha would slow down with the boost levels coming home.
I Pulled the intake side off and that wheel looks ok, the edges of the wheel are shinny but there is not much play in the shaft and it was not rubbing.
So what could it be?
