21 - 26 of 26 Posts
Discussion Starter · #21 ·
?????????? Why worry about a lifting eye??????????????????
You are missing some major components in the picture.
Turbo supply and drain. Fuel pump is towards the front.
Discussion Starter · #23 ·
Are you sure it looks like two mounting holes for the pump and it will be real close to where the pump mounts
Discussion Starter · #24 ·
I take it back RT you are right, I was scratching my head wondering what that brass looking thing was at the bottom of the picture was until I looked at it again. It's the fuel pump.
You have arrows and a circle on your picture. What exactly are you trying to do? If you do not have the factory lift point on the motor then you can simply bolt up another kind of mount or chain to remove the motor if you need to. As for the arrows if you do not have those parts, I think you are on the wrong section of this forum.
was talking bout the engine lift point mounts thank you
21 - 26 of 26 Posts
