Does the valley between your heads have much oil/diesel pooled up on it?
All leaks travel down & back, so follow it forward & up to the source. It'll be easier to find if the engine is clean (dirt spreads the fluid), so consider pressure-washing everything you can possibly blast, followed by a few rounds of PurplePower/SimpleGreen & a garden hose to get the last of the grit & oil off. Then you should see a straight trail from the leak (until the engine collects dust & dirt again).
