Got home today and found coolant leaking. I peeked under the truck and it is pretty much all over, but I haven't been able to get in and really look yet.
I heard radiators go bad in these trucks. Is this likely? If so, is it covered under warranty? I have 42,000 on my truck.
You have to determine where the leak is. If it is the radiator then there might be other causes.
Check the hoses, they are know to leak because of the 0-rings. Also hyperextended thermostats could be a cause as well.
Radiator by itself is not covered..but if there is another cause it could be.
Had mine replaced, but was still under 3/36k
