1 - 8 of 8 Posts
Trying to find out if LED bulbs are any good. Anyone switch the bulbs over and are there any fitment issues?
Which ones do yo have?
Which lights are you wanting it switch
Talk to Hucorey at CNC Fabricatins , (search his name) he has the Lifetime LED's , he'll point you in the right direction.
I fitted them in the daughters little car and they're working great , there has been so many threads on the best lights , you can do a search on them.
I went with the set below from Amazon. It was $100 and went right. I did have to cut down the locking nut for the bulbs. The pattern and disbursement seams good. Then do have a fan and heatsink on them as well.
Xenon-Vision 80W 6400LM CREE LED Headlight Conversion Kit - 6500K - All Bulb Sizes - 5202 (12086) Cree LED
I bought some cheapy ones off eBay that are working great.
They also patterned well. I faced the side with the low beans up and it doesn't have any scattered light.
The best upgrade is the 02 up clear lenses
I did the light change from the stock of the 9007 to the 6054 style in the van. The lights from Truck Light full LED , the same ones that are in the US Military rigs .. and even DOT if I remember correctly.
Of all the different styles that I have tried over the years.. this is the keeper.
I have replaced all of my interior bulbs with LED replacements and they are worth every penny I spent on them. Found them in the automotive section of Walmart. I even replaced the reverse lights, bed lights, license plate, door panel, and even under the hood with them and they made a huge difference. Not sure if it matters but they don't use near the power to run and don't get hot.
1 - 8 of 8 Posts
