Hello fellow IDI owners! I have always gone to the internet and used the resources to help me work on my 7.3 idi turbo. I have never spoke out or engaged in conversation on the forums about the IDI's.
I have had the truck for 6 months now and I've got it modified the way I like it and have some goals for it. I want to eventually get a intercooler set up along with a new IP and injectors. Before I do that, I have been trying to achieve 15 psi of boost and no more. I am just me, but I want to be sure to get 15psi before I dump any money into a intercooler. I have short ram air, deleted the squashed piece of the downpipe, muffler deleted to have the air flow in and out nicely and I have the waste-gate shut completely. My injection pump has been turned all the way up on the fuel screw and the torque screw backed out to where I like it, unloaded i get about ~4-5 psi and ~700 to 800 egt cruising 70mph on the highway, no smoke. But on the cruise nights in my town, i like to do hard 3rd gear pulls. It will blow smoke, take about a second to spool up and I can hit about 10 to 12 psi fairly quick all day long. I know increasing boost without an intercooler will not help me much because of the heating of compressed air. I would believe that the stock turbo is small enough to get more boost, and I have kept aware for leaks on the hot side especially at the y collector, but see no leaks there. I looked for possible obvious leaks on the cold side where the intake hat connects the turbo and the manifold and everything is snug. The hole in the back of the manifold is also tight. I am not trying to be like the powerstrokes and the cummins hitting up to 30 or 40 psi of boost, but I just want to know why this engine has such a difficulty increasing the boost? Is it due to high compression or the stock turbo not made to handle that kind of boost?
Thanks for any response or input!
