A friend wants to level his 00 F250 CCSB and was wondering the "best" way to do this? Wasnt sure if a complete new spring pac is needed or just add-a-leaf? What are some quality kits?
Zach. /ubbthreads/images/graemlins/wink.gif
a shackle kit is the way to go.
For a little lift, try the 3" donahoe kit with a Stock F350 rear block.
The stock shocks will work fine with the F350 block.
Obviously, if you have an F350, skip this block swap part.
That sounds good. What size tire should I expect to fit after the 3" shackle kit on an F350?
I would use a 295/75-16. They are load rated at 3415 lbs each. (same as the stock tires)
