Where the rubber line comes off the vacuum pump on my truck is less than an inch away from the exhaust manifold.
It burned a hole in the vacuum line which caused my brakes to go out. I got two 90 degree brass fittings and put short pieces of rubber hose in-between to try and keep the hose further away from the exhaust manifold but it is still close right where it comes off the vacuum pump. I also put 1200 degree spark plug wire cover material over the short rubber pieces to try to keep this from happening again. But it looks like the spark plug wire cover material is slowly deteriorating from the heat.
This problem occurred 6 months after my engine blew and I had it replaced with a 7.3 from an E350 Van. The mechanic who switched the engine took the vacuum pump off of my old engine and put it on the new engine out of the E350 Van.
Is it possible he could have mounted the vacuum pump the wrong way so that where the vacuum hose comes off the pump is closer to the manifold than it should be?
