I'm putting in a dash cam and looking for a full time hot fuse (BAT+) in the fuse box under the passenger side dash. I don't have uplifter switches, does anyone know if any of the fuses stay hot when the key is off?
Thanks,
You do know if you don't put a switch on that camera it will drain your battery. I would look for a fuse that only comes on with the key. There may be a spot where you can add a fuse and wire it to that fuse.
There's a customer use wire behind the radio, probably taped to the bundle that goes to the OBD port. Its fused power when the key is on. That's the one I'd use. My memory says its blue but Google sez its white with a blue stripe. Regardless of what colour it is it should have a tag on it identifying it as customer use.
