Ok so I've got several threads on here about my 05 f250. Had a hot no start problem to start. Did the stc fitting, stand pipes, dummy plugs and coolant hose on the egr cooler. Fixed my hot no start problem, then I started a whole new set of problems. Turbo wasn't working and I was having tones of codes. Got lots of advice on where to start and what to do, checked map sensor, that it was plugged in, checked map sensor hose, that it was plugged in at right spot and not clogged up. Pulled out egr sensor, cleaned it. Took out vgt sensor from turbo and checked/cleaned it. Checked ebp sensor and tube. Tube was un clogged and I have now replaced the ebt sensor and connector/pig tail. Truck was running ok but now while driving it has started surging, stalling, lunging forward and just loosing power as if it's about to just die in the middle of the highway. While it's doing this it is pouring heavy white/grayish smoke out the pipe and when I try to give it some fuel, it turns to a heavy dark gray/black smoke. It will do this for a few miles then finally start running normal, what ever that is for my truck now. I feel like I'm playing whack a mole with it, fix one thing and something else pops up.. I'm about ready to just torch it.. It's turned into a money pit...I've had it for about a year with no problems until the hot no start started. It's only got about 98k on it. The main codes it keeps throwing right now are -0472/0671. Other codes it has thrown are-0299/0470/2262. Any help/advice, recommendations for exorcist/torcher will greatly be appreciated.
