Status
Not open for further replies.
1 - 10 of 10 Posts
Hi I am trying to find a member 99SD Member #40608. He has some info on a Allison conversion I could really use. I am going from a Allison 545 to a Allison MT 643 Behind a T444e. He has a List of all the part and a Drawing form Allisn AS04-317. It would be a big help if I could get this. Thank You
99SD hasn't posted here since 2008. You might try sending him a Private Message, but after all that time, don't hold your breath. I changed your thread title which may help it to be seen.
1998 T444e trans change
Thanks Klhansen I am ok with computers, but not great your help is appreciated thank you very much. Would you have a Email address I could start with? If not I understand thank you.
I am looking for this parts list as well, however the link above does not appear to work anymore. Does anyone else have a list, or another link??
Thanks in advance.
The older stuff here on TheDieselStop isn't currently accessible, due to software "upgrades".
The administration has been asked to restore it, but haven't done that yet.
Send Administrator a PM. Maybe if enough of us do that (and I definitely have) they may come to their senses and restore the info. Lots of valuable material there.
Thanks Kevin, I needed a good laugh before the year ended.
Here are all the part numbers you'll need to bolt the mt643/653 up to a t444e, per Allison drawing as04-317.
1982 International S-1800 4x4 Fire Truck
From Navistar:
1821697c1 flywheel housing
1800777c1 ring gear
1818211c1 flywheel
25500r1 bolts, trans to engine, 12 needed
25709r1 hardened washer, 12 needed
1823406c1 flywheel bolts, 10 needed
from Allison
23014107 convertor nuts, 6 needed
29519143 crankshaft hub
23018900 flywheel housing adaptor
23045171 flexplate adaptor
29519142 flexplate
29514856 crankshaft wear plate
23046154 convertor washers, 6 needed
23049056 flexplate bolts, 6 needed
AT1545 thread - Page 11 - School Bus Conversion Resources
Still can't find the drawing. Hope this helps.
The OP hasn't been on since August 2019, so has probably wandered off to find the info somewhere else.
So I'm closing the thread, since tech questions don't belong in Member's News.
1 - 10 of 10 Posts
Status
