Anyone have any insights on a loose shifter? I can hardly feel the difference between each position (P,N,D, etc) I checked the torx bracket under the dash and it ain't loose. I can disconnect the linkage at the tranny and manually move the metal lever on the transmission. It clicks real well between each position. While I was overseas last year my brother stated the shifter broke. Him and his buddy replaced it with a Dorman shifter and he stated they also replaced the shift tube inside the steering column with (I'm assuming) a Dorman. Could this be the issue? I only use Dorman products for certain things, this would not be the time. I wonder if they replaced the bushings on the shift tube...
Thoughts?
