Would be nice to know what transmission and whether it's a 2WD or a 4WD. When asking questions about your truck.New to diesel have a 90 f-250 7.3 idi was driving an lost all gears all at once now will not engage any gear and a low humming coming from trans? Any good place to start looking? Thanks
^^^^^ This. FIRST thing, shift to Park, and see if the truck can be pushed. If it can, the transmission may be fine, and the t-case may be out.The first thing to check is the transfer case. Then the pump in the trans.
That means the problem is forward of the transfer case. It could be something inside the trans, the torque converter, or the flex plate. The best way to narrow it down is to pull the trans out and tear it down, unless you find a broken flex plate when the trans is removed.Yes it holds place when in park
