1 - 12 of 12 Posts
Well I pulled 2 genius moves and lost both sets of my keys for my EX. they were the "chipped" keys. what do I need to do get replacements and any idea on the cost I am about to endure?
Call a mobile locksmith up. Pretty sure that they can make a key. As far as the cost, a chipped key that needs to be cut from scratch and programmed probably not going to be cheap.
You will need to (obviously) get a minimum of two new keys. The PATS system will need to be accessed with a FORD IDS to get past the security screen and then erase all programmed keys which will allow the two new keys to be programmed. I mentioned the Ford scan tool specifically because I do knot know of any non-OEM scan tools that will preform this function or if there are, which ones. I am sure someone who knows if there are, they will chime in. Do not pay more than one hour labor.
I think AE have a option setting for the PATS. I will look into it today
found this on PHP website. might help you
· Super Moderator
When I bought my latest car with a chipped key the owner only had one key. I had a mobile locksmith make me a second key. Including programming it was $45. Now he did have my original to cut the new key, but it shouldn't cost a lot more to do yours.
Biggest issue is going to get keys cut to the current code. Dealerships will have the key code based on VIN but there is s time limit I believe. Once you have a pair ok keys, any locksmith with the proper equipment can program them.
Discussion Starter · #11 ·
I ended up having to get a local lock smith come out and do it nearly $400 for 2 keys cut and programmed.
1 - 12 of 12 Posts
