My 2001 Ford F350 isn't making much boost. The most I've ever seen is around 12 psi. I am running a 4" turbo back exhaust, edge juice with attitude tuner, upgraded compressor wheel. I thought this was normal boost until I saw what a buddies was running. I guess my question is where is a good place to start looking ?
New to the forum and new to diesels
What are you using to measure your boost? The Edge? If so, check the MAP sensor hose. Check for soot on the up pipes. Build yourself a boost leak detector and test for leaks on the cold air side. The Edge is not a great tuner, but you should be able to build at least 17 psi even with the worst tuner.
Just using the edge. Thanks for the info.
