My 95 van acts like it is dead on a hole and a half, of course I have checked what I can, changed the fuel pump, cleaned filters, changed the upper end oil, new filters etc... but still has the poor running problem. It does make good boost 15lbs+ all stock.
There is the chance of under cover harness being bad, I haven't pulled the valve covers because of the labor involved and if I have to do the injectors at the same time I want to have my **** together.
I have also been told that it could be a compression problem, my question is fairly simple:
If the unit is low on compression on one or more cylinders and the injectors are firing as they should, will there be excessive exhaust smoke from the unburned fuel being introduced into the low cylinders? OR if there is an injector (or two) that is not injecting will there be little to no smoke? (like it is)
Thanks in advance.
Thanks in advance.
