I had my fuel filters changed at the dealership today on my '15, and then I bought fuel and headed home (70 miles). About half way home I got a "Low Fuel Pressure" message and a little while after that "Reduced Engine Power" along with the check engine light.
I pulled over to see if they did something like leave the drain open, thinking it might be sucking air. Of course it was dark and I could not see anything. However I did hear a buzzing sound and could feel a vibration when I touched the fuel line going into the top of engine filter.
While it is possible I got bad fuel, I suspect they did something wrong installing the filters. Even after cycling the fuel pump multiple times they had a hard time getting it started afterwards; I think they finally disconnected the top fuel line to bleed the air out.
I continued home and made it, but not sure what to do now; its 70 miles back to the dealer.
What is the most likely problem? Improper fuel filter installation or bad fuel?
Should I pull the filters in the morning see if there is something obvious like an out-of-place gasket? If so, top or bottom filter?
Is this a tow truck affair or should I drive 70 miles back to the dealer?
What the heck is the buzzing sound?
Sorry about all the questions, just trying to figure out what to do.
