Hello Again All!
(2003 Ford F350 Lariat) (Codes read on Edge/Juice with Attitude Module)
My Dad and I have been attempting to diagnose our truck, which has been difficult. We did the oil cooler and IPR last fall (debris in IPR, no-start). Ran well for a bit, normal power and performance. We just had to do the oil cooler cover gasket because it was for some reason leaking (not Dorman, but we put a Ford part in this time). Oil leak is resolved at the moment. However, after finishing the work, the truck has had no power, which makes me think the repair process caused the issue. Visual inspection revealed nothing disconnected or loose, and I don't remember doing anything different from the first oil cooler job.
-Codes:
P0107-BARO/MAP Sensor - Been around for a while now, MAP is plugged in, and nipple on intake looks okay. Perhaps a hose leak or electrical issue somewhere else?
P0113-IAT High Input - Also been around for a long time, not sure what the issue is. Might try replacing sensor at some point.
P0266 and P0272 - Cylinder 2 and 4 Contribution Faults - Injectors? We have been having balance codes with the even numbered cylinders. These codes I don't feel are related to loss of power, because they've been around for awhile.
P0673 - Glow Plug #3 Circuit Open-Replace Glow Plug 3, or issue in GPCM?
P02127, P2136, P2140 - All Throttle Pedal-Related codes. I have read other forums about these and similar ones. One problem I read about is the EBP harness, which I have checked everywhere I can. The air filter in our truck is aftermarket (Magnum Force AFE), and cannot be removed without taking out coolant bottle, I don't think. Therefore, inspection of the harness at this point is difficult.
P2264 - Turbo/Supercharger Boost Not Detected/Mechanical - Wondering if this is just a "dummy code" because the truck is have throttle pedal/sensor problems. Could there be turbo issues though? FYI, turbo isn't stock. It is a non-VGT Turbonetics T4 (I think?) Compressor wheel spins freely, but I have had a persistent exhaust leak at the down pipe, which wasn't fixed by a brand-new clamp. Any advice on that leak would be appreciated.
P0500- Vehicle Speed Sensor (VSS) Malfunction - Also a dummy code because of lack of acceleration?
-Symptoms
No Boost
EGTs drop when climbing hills (kinda weird...)
Struggles when loaded down or climbing hills
Getting from 0 to 60 is difficult, even with pedal to the floor
Various trouble codes as described above
Engine runs a little hotter (190 F) used to be around 174 F
I know that a scan tool that can read live data will be something I'll be asked about. We don't have one, but I am open to getting one if it is truly necessary (I want to save the money if I can though). Feel free to tell me what the best brands are, but I want to see if this could be resolved without one (not that I won't need it later on). Thanks in advance!!!
-Codes:
-Symptoms
No Boost
