I have a leak where my hydroboost meets the master cylinder. I can see the drip on the bottom side with the use of a mirror. Its been leaking for some time and I'm not sure if there is a seal between the two components that can be replaced or if the hydroboost is failing (the fluid leak is ATF, not brake fluid).
I'm leaving for a road trip Sunday and was thinking about putting a bottle of Lucas Oil Power Steering fluid w/ Stop Leak in the power steering pump. It says its compatible with all power steering but I wasn't sure if it is with ATF????
Does anyone know if it will hurt the system? Don't wanna make a little leak worse and have this grenade on me going down the highway w/ a trailer.
Thanks in advance for the help.
4fun
4fun
