I am embarrassed to admit, but I’ve been really bad about the maintenance I have not done on my cooling system. My truck currently has about 131k miles on it and so far I haven't had any issues with water pumps, thermostat or leaks. But I also haven't done a darn thing to it either, haven't changed the coolant let alone test it.
I will be replacing the thermostat since I will have it apart to do the flush procedures, but do not know whether I need a new housing? Also, do I need to purchase a separate “O” ring, or does it come with the thermostat or with the housing (if I need that). Most people here say that you should coat the “O” ring with RTV when reinstalling, do you just put it on the ring or the mating surfaces also. What kind of RTV, Black Hi-Temp? Should I use new bolts too and use anti-sieze on the bolts?
Should I replace the pump too? I really don’t know I want to drop another $200+ on the pump since mine hasn’t given me any problems so far, but am I riding on borrowed time? Since I haven’t maintained my coolant, I can’ t believe its lasted this long. If I wait, does the pump give you warning signs that its going out or is it sudden?
I am adding a coolant filter to my truck as well, figure better late than never. Do I add this after I flush the system?
Already have new hoses waiting including the dual alt one.
Lastly, I am thinking about switching from the gold over to the HD ELC coolant, but undecided on that. If not replacing the water pump, does that impact the decision on the water pump if I switch? I have found the Chevron Delo ELC locally for $18.03 about the same as the Gold from the dealer.
Sorry for all the questions, I don’t want to miss anything.
