I have a new to me Excursion and am looking to benefit from the wealth of knowledge out there. I plan to change the ATF (w/ filter), differential fluid & coolant for sure. I was wondering if anyone had suggestions for anything else to include. There are 82K miles on it.
Is there a recomended change interval for the blue/orange tubes?
Looking for any advice to save $$ down the road.
Thanks. I had heard to avoid that like the plague. I found some archive descriptions of the procedures that look good.
· Banned
Have you seen this, http://www.thedieselstop.com/faq/1999faq/Maintenance-AutoT.htm
Works like a charm flushing the tranny.
If you don't want to do Oil Analysis, I would use a good oil and change it every 5,000 miles (engine oil).
If you want to use oil analysis you can go as long as they tell you on good oil, I prefer Synthetic such as <font color="blue">Rotella Synth 5-40 or Schaffer's 9000</font> and go up to 10,000 miles plus.
A good bypass filtration system is one of the best investments you can make, especially if you plan to keep her a while. The http://oilguard.com unit works well and is priced better than the http://fs2500.com
I would change all the diff and Transfer case fluid at 100,000 miles
Then get that stock coolant out of there and go with a good ELC (Exteneded Life Coolant) such as Fleetrite
I saw that miantenance link in an archieve post, very helpful. I'm thinking I may do the belt before I start towing for the summer.
Thanks.
