Just a friendly warning of what I learned the hard way regarding Diesel Exhaust Fluid. To make a long story short I was distracted as one of my guys went to fill up my DEF tank in my 2011 f250. Due to me taking a cell call approximately 1 gallon of the fluid was poured into the wrong tank (the diesel tank) before I noticed. If you guys don’t know the DEF and diesel fill ups holes are right next to each other on the fords (not a good idea). I am not very familiar with this fluid, I read the back of the DEF bottle and not seeing anything that concerned me about mixing a bit of the DEF in the diesel tank I did not think too much of it. I thought after all they are meant to burn together and I just filled the truck up with about 27 gallons of diesel and if it could really cause harm it would be posted on the DEF bottle. After driving it for a while, it quietly stalled and I coasted to the shoulder, turned the key a few times with no luck then had it towed. I was initially informed that it would cost $9,000 to repair the damage. After the work was performed After just getting of the phone with the ford dealer we are now up to well over $20,000.00 in damage and in need of a new engine and fuel system on a 2011 truck with 25,000 miles on it. Due to this mistake.
Ultimately the reality is that I have no one to blame for this but myself. But if one gallon of this fluid can do this and the tank fills are right next to one another I can’t help but think I’m not the first to do this.
And likely won’t be the last. After spending tens of thousands keeping a few of the past two generation ford diesels running I told myself I would never get one again. A bit back one of my company trucks diesels blow a hole in the block at 17,000 miles. That at least that $25,000 bill was covered under warranty. My other ford diesels were just endless money pits.
I don’t know why but I found myself at the dealer sitting in a new F250 listening to the sales men tell me how it gets over 20 miles to the gallon and how much HP it has. I was also told that I would never have to fill up the DEF tank and it would be filled only at oil changes. Ford designed it to not need to be filled between oil changes. Before I knew it I was driving a truck with way less power than I imagined averaging about 14.8 miles to the gallon as per the ford computer but I think it was lying a good bit. I was also filling up the DEF tank twice in between oil changes. So now not only do you have to make sure you have enough fuel to get places you need to keep an eye on the DEF, and the DEF Can be tough to find.
Like I said this one is my fault, but help me out a little bit. Freightliner vans have been using this fluid for several years and the fill up for the DEF is under the hood. And dodge Cummings meet emission requirements without needing DEF. I almost feel like ford designed it this way for failure to make a few extra bucks.
Below is an email I just received from the dealer
Mr. Mcdonald,
As per our discussion, I am providing you with a breakdown of what repairs have been performed and repairs still required to address the damage done to the fuel system and engine caused by the fuel contamination when the diesel exhaust fluid was added to your fuel tank.
When vehicle was towed in to Larson Ford it did not start or run. During our discussion over the phone you described to me that one of your employees had mistakenly added DEF fluid to your fuel tank and that the vehicle was then driven until it shut-off and would not restart.
Upon initial inspection the engine would not turn over either by starter or manually. When Ford was contacted to inquire about the possible effects of this contamination we found that a possible reason the engine would not turn would be due to high pressure fuel pump catastrophic failure, which would jamn the gear that is connecting the engine to the hp pump. Removal of the pump was required to see if the engine would turn. Also, this type of failure requires complete replacement and cleaning of required fuel system components.Upon obtaining authorisation for pump removal, we dissassemble to the point of pump removal and found the engine would turn manually. As we still could not start the engine, fuel system repairs were required and authorised to enable starting of the engine. the required fuel system repairs totalled $9035.00+tax which included fuel supply pump, high pressure pump, fuel injector manifolds, fuel injection steel lines, fuel injectors, fuel filters, all needed gaskets and seals. Also included removal and cleaning of fuel tank, supply and return lines.
Upon completion of fuel system repairs, vehicle started and ran, but ran rough. Engine diag for missfire determine no contribution from 2 cylinder, no compression.Informed that a partial teardown of engine was required to determine extent of repairs required to engine.Upon authorisation and teardown found several pushrods, rocker arms and valves damaged, also found valves had contacted pistons causing further damage to lower internal engine components.
When comparing replacement of damaged engine components to "longblock" replacement, it was determined that "lomgblock replacement was the most cost effective repair. Parts and labor for "longblock" replacement total additional $13997.00+tax.Bringing the total repair cost to $23032.00+tax. This total cost includes all fuel system components already replaced, all needed seals, gaskets, engine parts and fluids, and all labor charges to complete repairs.
Due to the cost of the parts required Larson Ford requires a deposit to account for parts and labor already invested in repairs and to order the engine "longblock". deposit required is $12,500.00.
If you require any other information please contact me by phone at 732-363-8100 ext. 505 as this is the most effective contact method.
Thomas Fortin
Assistant Service Manager
Larson Ford
1150 Ocean Ave
Lakewood, N.J.
08701
Mr. Mcdonald,
Thomas Fortin
Larson Ford
1150 Ocean Ave
Lakewood, N.J.
08701
