This post was by SmokeyWren , on 01/01/09
Sorry Smokey for hijacking your post, just trying to make a point.
Please don't confuse me with any sort of an engineer, but I can give you an educated guess in laymen's terms.
It's because the torque converter in a modern automagic tranny multiplies the torque available to get a heavy load moving in adverse conditions, such as when parked facing uphill on a steep grade.
When it was stock, my '99.5 7.3L automatic had 500 lb/ft torque. But the torque converter increases that to almost 1000 lbs/ft when you first began moving up a steep grade dragging a heavy trailer. The stick shifters have a max of 500 lb/ft torque, regardless of how much you slip the clutch. So the automatic can begin moving a heavier load than a stick shifter with the same engine.
And the torque converter is designed to slip, so you don't hurt anything when you are slipping the unlocked torque converter to multiply the torque to get a heavy trailer moving. But you can do some damage if you allow a clutch to slip more than a little bit.
Other than getting a heavy trailer moving, the automagic is also better for towing on the edge of lugging the engine. The engine cannot lug with a 4R100 or 5R110 automatic, because the computer-controlled tranny will downshift before the engine begins to lug. But for a stick shifter, the driver is the computer. So the driver has to understand what lugging is and not allow it. That's asking a lot of some drivers.
Below by me.I agree with him completly.
As far as the new so called manual transmissions, that are computer controlled, I wonder if they don't have a WET clutch or if the clutch is engaged "SMOOTHLY" until the truck shows movement to the computer.
But what I'm darn sure of is that you are NOT able to get a COMPUTER CONTROLLED MANUAL IN AN F SERIES Ford truck.
Take your pick, a ZF5-6 or an Automatic, I'll take the auto any day.
