I just got a 29' 5th wheel camper and know that my EOT and ECT will be going up as a result during towing. What is the maximum EOT before I need to be concerned ? What temp does oil start to break down ?
If I remember right I think that the motor d-rates at 250 degrees oil temp. Syn and Dino oil can go to 300 degrees for short periods of time before it has problems. I have seen water temps as high as 240 in my 7.3 without it even loosing coolant
IMO you should be more worried about the EGT when towing.
I upgraded to a 4" exhaust but do not have pryo gauges. What are the max EGT ?
Ideally your oil should run in the 200-220 degree range. It actually works best at those temperatures. 230 degrees is getting quite hot, and by 240 the oil is starting to break down. 250 is the point at which the engine is derated, but IMO that's too late. I always advise anyone who's had this happen to get the oil changed ASAP. Once you cross 240 each degree is more and more dangerous and the oil breakdown is not linear with temperature; its exponential. The big issue is that oil takes a while to cool down. Unlike coolant, which is water based and great at rejecting heat, oil is not great at rejecting heat.
ECT of 240 is getting pretty hot, but with system pressure in the 6.0 it would take 250+ to get it to boil over.
Do not exceed 1,250 for more than a minute. The hotter it gets the more quickly things will melt. When in doubt lift a little and the EGT should drop. You should be able to modulate it with your right foot.
