why do we not run mercon v?
1. Because it is not designed to be used in a 4R100
2. It will cause problems at some point if you believe one who should know as discussed <font color="red"> HERE</font> and <font color="red"> HERE </font>.
3. I believe Mark /ubbthreads/images/graemlins/cool.gif
Larry, keeper of the <font color="blue">"little secrets" </font> CLICK HEREhttp://forums.thedieselstop.com/ubbthreads/showflat.php?Cat=&Number=1173329&page=0&view=collapsed&sb=5&o=31&fpart=1 /ubbthreads/images/graemlins/smile.gif
Because in the owner's manual and Ford's service info it says that MERCON V can cause damage to the E4OD and 4R100 transmissions.
Why do we use diesel rated engine oil instead of regular engine oil? Because it is the right fluid for the job. Same with the transmission fluid.
