Does anyone know how to get the mirror glass out of the housing on the passenger side?
The plastic trim that goes around the mirrors is broken on one side, and I found a new one, I am just not sure how to go about tearing the mirror apart to replace it.
Rick
You need to push the top of the mirror all the way in & the outer edge in also so the bottom inner corner is out. There’s a little slot that a 3mm screwdriver will fit in between the glass & the gray mount turn the screw driver to pop it out of the holes and then you should be able to remove the glass.
