Decided to install the Moroso pn 27293 oil pan gasket last weekend, to correct a very minor oil seepage problem I noticed at the front and rear of a used/rebuilt engine I’m in the process of swapping into my F250. Below is the process I used, note that all of this was done on an engine that was out of the truck, upright on a stand (not flipped over).
1. Used a single edge razor blade to cut into the old silicone all the way around, then carefully hammered in a gasket scraper in various locations, using it as a pry tool until the pan finally came loose (see first pic).
2. Removed most of the old silicone from both the block and the pan with a single edge razor blade, then did final cleanup with a wire wheel on a drill for the pan, and with a small stainless steel wire brush for the block. Wiped everything down with paint thinner and/or brake cleaner (my two favorite solvents), then blew out the pan with compressed air to make sure all silicone particles were gone.
3. Screwed the supplied studs into the block with blue Loctite, leaving slightly over 3/4" sticking out of the block as per Moroso instructions.
4. Put a small amount of silicone on the block at the 4 corners where the block matches up to the front and rear covers, as per Moroso instructions.
5. Installed the gasket onto the block. The gasket has metal inserts in the holes to prevent over-tightening – these also help to hold the gasket on the block as they are very tight on the studs, so tight that I had to use a socket to hammer the gasket onto the stud in a couple of places.
6. Put a small amount of silicone on the bottom of the gasket at the 4 corners per Moroso instructions, then attached the pan to the gasket using the 12 supplied 1/2" nuts and tightening to 10 ftlbs. Note that I tightened only to 10 even tho the instructions say 12-15 for reason below in my observations.
Observations
A. First, the thick blue gasket looks really nice and complements my Ford Blue color scheme, you know that’s important!:lol:
B. Since the pan is about 1/4" thick, and when you tighten the nuts it slightly bends the pan at the tightening points, and kind of pooches the gasket out as well at those points – you might be able to see this if you look closely at the second pic. Because of this, I loosened the nuts a bit to 10 lbs, instead of the 12-15 recommended, and I think I am now going to try to correct this by inserting a piece of ¾” by 2 ft long flat stock drilled at the stud locations and attached between the nuts and the pan. If this works to even out the holding pressure of the nuts as I think it will, I will suggest to Moroso that they include this part in their gasket kit in the future!
C. Since the pan is ¼ inch lower, I had difficulty re-attaching the dipstick tube to the valve cover bolt. This may also have been partly due to my bending of the tube a bit as I was forcing it into the new oil pan flange that I installed at the same time, but it does make sense that your tube will not fit in the same place without some re-bending since the pan is slightly lower. In my case, I decided to make a short extension to attach to the dipstick bracket, which you can see in the third pic.
D. I’m sure the dipstick will no longer be completely accurate either, so I plan to scribe it after I fill up and run the engine with the required 15 quarts.
E. Lastly, this job would be extremely difficult to do with the engine in the truck. I don’t see how you could remove all the silicone – which is required to prevent leaks per the instructions – without filling up your pan with silicone scraps if the engine was still in. And don’t even think of removing the pan without removing the engine (as I’m sure everyone knows) - no matter how far you may be able to jack it up, the oil pickup tube extends so far into the very deep pan it will prevent pan removal.
Observations
