I just lost compression in #8 cylinder, I believe due to a ring or piston, valves are in working order and I felt somthing down in the cylinder with a piece of wire? So I was wondering what year s will interchange with it.
Thank Tim
the long blocks are basicly the same on all the 7.3, difference are the hpop, injectors, valve cover harness, computer, and rods in the early 02. so if u can find a good running long block from any year you will be fine.
