Wouldn't stage I's put me well over the "Safe" mark? I only tow in the summer time (7K boat) and the rest of the time I am unloaded and racing everything that moves. Even with the new HPOS I am throwing a bunch of smoke in the 80HP setting so I thought the 'Bigger turbo in a bottle' solution was possible.
I would want more controlled boost than the 'turbo in a bottle'. If you can't drag any more boost out of the BB, then I would look at an H2E, although I think the BB will do the job w/stage 1's.
Remember, bigger injectors will spool the turbo harder and make it clean up better, more boost.
Take a look at this thread,
Click Me it has a lot of good info on making PMR-safe power.
This is a quote take from
SappsPSD in that thread.
***** DP-TUNER 6 POS *****
BDP Stage 1 Single shots
Stealth HPOP
H2e
Full Fuel system with pickup and SX pump
intake, exhaust and trans or clutch mods of course
This is one serious towing setup. Over 250K miles on the clock towing commercially across the 48.
It would be very important to have the proper tuning, and you may not squeeze every drop out of this setup, just a good reliable program that won't be snappin rods.
