I have a problem, my 2008 F250 has been sat a while, I went to start it the other day and it will not crank.
I have checked the batteries and fully charged both of them to 100%
When I turn the ignition key I hear a relay click on the passenger side fuse box
I have tried to start it in P and Neutral with the ebrake on.
Nothing, I have checked all the fuses and they seem okay, I cant check to see if I hear the relay under the hood as I am on my own.
The truck does everything inside it should,, radio out info display out when key turned to start etc.
Ok I checked the error codes
P0546 Exhaust Gas Temp Sensor Circuit High Bank 1 Sensor 1
P2033 Exhaust Gas Temp Sensor Circuit High Bank 1 Sensor 2
P242D Exhaust Gas Temp Sensor Circuit High Bank 1 Sensor 3
P0405 Exhaust Gas Re-circulation Sensor A Circuit Low
P1335 EGR Position Sensor Max Stop Performance
P2455 Diesel Particular Filter Sensor A Circuit High
I tried to but the codes would not clear.
Stuck out on a limb here, any help would be very very much appreciated,, thank you
