Ok... as I stated in an earlier thread I threw about 5 gallons of filtered WVO into my 3/4 full fuel tank last night.... making the blend of #2 to WVO about 90/10.
This morning, my wife gave me a list of errands to run. I started the truck and started the 15 mile drive into town.
About 7 miles into it, I lost nearly all power with the engine... and it started sounding like it was only firing on 2-3 pistons. I could not get the RPM over 1500.
I nursed it along for about a mile... then finally found a place to pull over off the road, and let it idle. It surged a few times, then died.
I sat in shock for a few minutes... (wondering how I ever managed to convince myself to pour waste oil into my gas tank)... then tried to turn the key again.
The truck fired up... surged a bit, and immediatly started running rough... no power, not all cylinders firing.
But.. it didn't die. I decided to try to nurse it back to the house to see what I could do. What a miserable 10 minutes that was. I couldn't go more than 10-15 miles an hour, and my exhaust was pouring out white smoke.
Then... about 2 miles from my house, my power started to steadily increase... until finally when I got back up my (long) driveway, it was at 100% again.
I decided to turn around and run back into town... thinking that it might be better to keep it running at this point than to immediately shut it down. So... I went back into town... ran all of my errands... the truck gave me no problems. I have stopped it and restarted it a few times since then as I was in town.
Here is what I THINK happened... please correct me if I am wrong: I think that I had some WVO that collected at the bottom of my tank that didn't mix/blend with the #2 that was in there. It took a bit to run that cold stuff through, but once it did, it seemed all good.
Question 1) Does that seem like a practical reason?
Quesion 2) Would anyone guess that I have done any damage to my engine? I limped along for 8 miles... for about 30 minutes. After that, the engine went almost immediately (within a mile) back to 100%.
Question 3) For others that are doing blends, what are you doing to help ensure that this stuff is 'mixing' properly?
Thanks in advance,
Halitosis
Thanks in advance,
Halitosis
