I was able to score a E350 15 person club wagon with only 115,000 miles on it for $4900. The main purpose of this purchase is to travel the US for 2 months this summer, and then turn it into a 4x4.
Only problems are one of the rear leafspring shackle was broken (from rust), the right front wheel has a bunch of camber and has worn the inside of the tire a lot, AC doesn't blow cold, and the ABS light is on, and the cruise control isn't working.
Right now I am in the process of making a list of all of the maintenance that needs to be preform:
Oil, transfluid and filters, fuel filter, air filters, and rear diff fluid, coolant was recently flushed.
Anything else I should do?
My question is how do I know what rear diff I have, and what weight fluid do I need?
Later Upgrades:
Brakes
Wheels & tires- 265x75r16 or 275x70r18 (not sure if ill have to cut the fender)
oil cross over
fuel cross over
fuel banjo bolts
up pipe & and turbo back exhaust
Dp tuner
front end conversion
and hopefully fit an intercooler somewhere
How does that list sound?
Later Upgrades:
Brakes
oil cross over
fuel cross over
fuel banjo bolts
Dp tuner
