1 - 18 of 18 Posts
Hey guys I'm new to the forum from Northern Ca and am hoping I can find some help along the way on my newest project. Here's the details.
A 94 f350 4x4 7.3 idi with ATS turbo and down tube. This truck was a maintenance truck that had the cab damaged when it had around 25k on it. My buddy picked it up and did a cab and dually swap with parts from an 87 f350 he had lying around. He worked on it a bit then let it sit about 8 years. It was never really completed.
I picked it up out if the field last week. I brought two new batteries and hot wired it and got her running to drive onto the trailer. Even after all that time it started quickly with a little shot of ether.
Nothing works in the truck. The ignition cylinder spins, the dash doesn't do anything but the door chime works annoyingly. Apparently the truck has an e40d and I'm told due to the cab swap I need to buy a trans controller?
My plan is to clean up the wiring, replace all the fluids and belts and hoses. After I get things right I'll worry about cosmetics. The pics make it look in better shape than it is. But she is pretty straight and virtually rust free.
I'm mostly going to use it to pull my toy hauler for camping trips.
I'd post pics but apparently I need more than one post.....
Discussion Starter #2
Made some progress this week. Sorted a bunch of loose wiring and although it doesn't start with the key the gauges work and the key shuts it off. I'm in the process of tracing the ignition wire that goes to the solenoid. I replaced the ignition switch but now I'm suspicious of the neutral safety switch.
Welcome aboard The Diesel Stop!
I've sorted through rats nests of wires before on my old '85, I remember the headache that was. Best of luck to you. There is a wealth of knowledge here to assist you if need be!
Discussion Starter #4
Thanks Cameron. I am very curious about a part that looks like it should have a 3 pronged relay under the hood. But can't find it on any diagrams. One thing that makes this tough is it's an 87 cab on a early 94 frame. I don't know how many posts I need to be able to put up pics but when I do I'll put them up in a build thread.
You're just going to have to trace it back to its origin and determine where to go from there. Trucks with cab swaps don't always go as planned and you end up with 'extra' wiring. If you find where the wires go to, you should be able to figure it out from some diagram. Even if you don't have a 3 prong connector on the wires you can always buy replacements.
Discussion Starter #6
Yeah I ended up ordering a toner for tracing wires. It should be here today. Then we will see where exactly the wires go.
Discussion Starter #8
That's the beast, she looks better in pics, the paint is pretty rough close up. I got the toner and a power probe, so I'm going to get the wiring sorted soon I hope.
A little elbow grease and she'll be looking like new! That's a nice rig you got there.
Discussion Starter #10
I traced the tone from the starter solenoid all the way to the switch. Tested switch with a test light and it works. But somewhere the 12v isn't getting to the starter.
I've got a 93 specific manual coming soon so maybe that will show me where I'm losing power.
Discussion Starter #12
So I've updated on oil burners but not here...
I've been busy gathering parts.
I got everything for a zf5 swap! Steering column, pedals, tranny, shifter cover, clutch reinforcement, gauges and scored hydroboost off the donor truck. Still need to but master slave combo.
I also need to order a water pump and thermostat and heater core.
I've changed the oil and hoses but there is still gunk I'm going to flush out before I put in the new pump!
My next step is going to be to remove the bed and clean the rear of the frame and add new electric fuel pump, fuel lines and brake lines. Re paint and re install.
I've got a pile if parts and even scored a really cool winch bumper that I'm going to fix up.
I'm only a few projects away from moving the whole thing into my garage and going to town on it.
The trans had a crack in the bell housing so I'm waiting for that to come back from the welder that should give me time to prep everything else.
Discussion Starter #13
Trans is welded up, almost ready to go in! I did electric fuel pump, new belts and hoses, new radiator, starter, alternator, heater core and fuel return lines. I've been collecting parts and looking to put big tires and wheels underneath her. I found a ten year old thread where Briansshop put huge 38's under a dually rear end and they looked awesome I'm going to do something like that but maybe with military 37's possibly?
Been doing a majority of my build posts on oil burners but I'm trying to remember to update here too. Wish me luck!
Good luck looks like a good project.
Nice looking truck. Where abouts in Cali are you?
Discussion Starter #17
Finished up most of my motor work for now. Now to move on to the zf5 swap and the hydroboost swap.
Engine is looking good. I'm down in Modesto.
1 - 18 of 18 Posts
