41 - 60 of 60 Posts
LOL /ubbthreads/images/graemlins/smokin.gif
Discussion Starter #42
How is the daily driveability of the 120 tune? I don't think I need that much but it sure would be fun. How did that tune effect mileage?
I have no problem with the 120hp daily drivability. The shift points cruising around are altered slightly higher but doesn't bother me. I will say, if your transmission is weak, this program may expose it. The great thing is there is not much smoke at all if you don't floor it. If you nail it to the floor though and boost is low, you will see smoke.
Hammer
So they are replacing the 6.0 not the 7.3.
[/ QUOTE ] I thought the 6.0 replaced the 7.3???? /ubbthreads/images/graemlins/shrug.gif Unfortunately hehe,,,, /ubbthreads/images/graemlins/biggrin.gif
Thanks for clearing that up. Now i'm sad.
i hear you can get the 7.3 in other countries
Personally, I'd prefer to see 'em build an in-line six so they can build a bottom end into it to rival the Cummins 6.0, oops I mean 5.9.
Then you'd have something to build on!
Thanks Hammer
Does jody sell computers? I need to replace mine that the dealer reflashed from NVK2 TO MRT1. I would like to go back with a nvk2,3
or4
Thanks for any help!
Discussion Starter #48
or4
Yep Jody sells used PCM's He just doesn't always have them though. It's a matter of his suppliers getting the used ones to him. I recommend that you give him a call and ask to see if he has any or when he expects another batch. 1-828-712-1405
Hammer
Discussion Starter #49
Personally, I'd prefer to see 'em build an in-line six so they build a bottom end into it to rival the Cummins 6.0.
I know you meant cummins 5.9 /ubbthreads/images/graemlins/cool.gif
Hammer
or4
Hammer
We do now, big order just came in of NVK's.
Are they new? and OEM? I just replaced mine, I even purchased it from the dealer with the serial number off my true NVK4. The NVK computer is being replaced with different compatable code. I'll have to go look because I can't remember the updated code. Anyway I tried to plug in an old TTS single bank chip that I ran for 3 years (great chip) and it was not letting my truck start. So the NEW computer that I purchased from [email protected] was not really a NVK. If you can get the real NVK computers I'll take one.
Blow_By,
Used. If you want it NVK4 he can make it that for you. Send Jody an email so he knows what you are wanting. Thanks
Diane
Can you burn one of your programs onto a gold superchip. It currently has an 80hp superchip program on it, but I would like a little more power. I sent an e-mail Friday but haven't gotten a reply.
Ryan
Can anyone tell me Jody tipton e-mail address. And thanks for the phone number, I am at work and can't make calls.
I like my DI 4-pos chip, but I'd REALLY like my PCM to lock my t/c after it shifts into 2nd gear or there abouts and keep my t/c locked till I slow down to around 20-25mph. Is the t/c control programmed into the PCM only or can it be added to chip programming?
Thanks, Trav
Its in the programing, be it with a flashed pcm or a chip, doesn't matter, Jody can take care if either for ya.
i just got my chip reflashed by Jody ... i've never understood what people were talking about "TC locking" .... but now i do ... Thank You DP-TUNER
thomas
Can you "stack" anything with a flashed PCM? Would it be worth it? If my PCM was flashed to say like 120hp, would my fuel milege be the pitts? - Chris
Discussion Starter #60
Theoretically you could, but Jody can raise or lower ICP pressure to your liking in programming and therefore stacking would not probably be very beneficial and would more than likely hurt you unless the ICP pressure was set low in programming. In fact, speaking of that, I'm sending him my other PCM to be programmed the exact same way except with a little higher ICP pressure. My current flash will NOT set of the ICP pressure code so I kinda wanna see if I can push it up a little. It will bring a little more throttle sensitivity back also.
Hammer
41 - 60 of 60 Posts
