Please help? Something happened in my steering columnn and now the ignition, or whatever it is called, won't crank all the way. When I put my key in I can turn it to the point before where you start the engine. I can start the truck by going to the starter solenoid with a wrench. I turn the key as far as it goes & go to the starter solenoid and it starts and runs. But, I want to fix this- any ideas what the problem and solution might be? I am an amateur mechanic. Thanks.
