On my 86 E350 Van. Last night, after starting, heard a whirring coming from the passenger side. This morning, no start. So I crawled under after work, pulled it off set it up on the work bench, and theres a puckered dime-size hole on the housing. Pulled it off and found bits and pieces floating around.
HERE'S My Question: While pulling off the starter, I noticed that the ground wire, or what appears to be the gw, from the passenger size batt had been cut and taped. Why would somebody do this? Could it cause my problem? This conversion van's previous owner's did a lot of electrical add-ons.
