Packing wheel bearings, that is. /ubbthreads/images/graemlins/smile.gif
The experts say you should re-pack the wheel bearings on your trailers every year, or about every 5,000 miles, whichever comes first.
It's a nasty, messy job, and I hate doing it, but it's necessary if you don't want to have axle problems on the road, so somebody has to do it.
Last year I chickened out and had my RV dealer do the task on my 5er. Apparently they didn't do it "right". I took off on a long trip. A little more than 4,000 miles into the trip, on Friday afternoon, in the hot desert of western New Mexico, I burned up a wheel bearing and ruined an axle. It was around noon on Tuesday before I could obtain and install a new axle. Wasted 5 days, several hundred miles of driving the unloaded PSD to get the new axle, and not a fun job replacing that axle in the dirt of a desert campground. /ubbthreads/images/graemlins/frown.gif
So today, preparing for a towing trip over Memorial Day weekend, I decided it was time to re-pack the wheel bearings on the 5er again. And this time do it myself so I know it's done right. I finished one wheel by manually packing both the inside and outside wheel bearings, then decided it would be worth a bunch of money to have a wheel bearing packer machine.
I got on the internet and found a Lisle Bearing Packer for around $25. Less than I expected. Then I decided that maybe an auto parts store would have one similar to the Lisle. I started with the itty bitty auto parts store only 4 miles up the highway, and sure enough they had one Lisle in stock. $25 and change out the door. They had another model by Lisle too, less than $10, that used a grease gun to force in the grease. But they didn't have any wheel-bearing grease in a cartridge that would fit a cartridge grease gun, and I didn't want to pack my wheel bearings with ordinary grease-gun grease, so I bought the $25 model.
(Do they still make the grease guns that don't use a cartridge? Just pack it full of grease and screw it back together? That's what I used as a farm kid in the '50s.) /ubbthreads/images/graemlins/shocked.gif
With that bearing packer and a medium-sized vice with a 6" span to squeeze on the bearing packer, I was able to pack 4 more wheel bearings in a few minutes. Much, much easier than the old-fashioned way of scraping the inside edge of the bearing dozens of times across your grease-coated palm. And a lot less messier. /ubbthreads/images/graemlins/smile.gif
The instructions say you can simply push on the bearing packer and create enough pressure to force the old grease out and the new grease into the guts of the bearing. But then it gave the option of using the vice - in case you use really-heavy grease. I had a suitable vice, so I used it. Worked great!
Click here to see the one I bought - although I bought from my local auto parts store, not from Northern Tool.
Well, gotta go out and do two more wheel bearings, and that nasty job will be over for another year. /ubbthreads/images/graemlins/warmsmile.gif At least on that trailer. The three utility trailer will have to wait a bit longer. /ubbthreads/images/graemlins/blush.gif
