2007 6.0 f450. Looking for an hpop to run 225/100 7mm hybrid injectors. Warren diesels site says a good stock hpop will run their hybrid injectors fine. I am bulletproofing the truck Here soon. would like to know others experience on this. I seen the adrenaline pump as well. Or is their a hpop out there that would work. I also seen the thumper I.
You can use stock hoop if it's in good condition on 7mm hybrids. I know someone that ran 225 on a stock. But he went to 430/ 300 then went duals. He somewhere in the 1200 1500 HP level now.I'm rebuilding my 06 6.0 now. Everything looks great accept the heads were all crack up, must have been a comedian that designed the Ford heads..
