Have an 89 7.3. On top of the passenger side farthest forward injector is what appears to be a restrictor of some kind. I can't get it to stop leaking where it screws on to injector. Should I just bend the fuel line and eliminate the part or ??????
Maybe it just hard to picture what you're saying. Can you post a picture???
The part your describing is the timing ferrule. Can you remove it?
Yes. If you can find another one, I would replace it. All F series engines will have it on #1 injector and E series will have it on #4 injector.
Reactions: ford_doctor
What Chuckster said. ^^^
...Where it screws onto the injector. Are you sure the return o-rings aren't leaking, making it look like the ferrule is leaking?
